1999 S70 GLT Ticking Sound
hotdog067
Year and Model: 1996 850 GLE
Has thanked: 3 times
Re: 1999 S70 GLT Ticking Sound
Post by hotdog067 »
Thanks abscate. I also noticed with the oil gauge installed, when the engine is cold, oil pressure goes up to about 75ish... almost near the end of the gauge (80 is the max in the display)... but when the engine has reached normal operating temp it settles at 25-35 when idling... increases when rev'd...
Could that high oil pressure when cold a sign of something going bad?
Has thanked: 1497 times
Been thanked: 3810 times
Cold oil is thick and that pressure doesn’t seem out of line. An air cooled VW with a puny oil pump will run 50-60 psi at cold start.
No worries. Are you running a 10-30 or 10-40 oil?
hotdog067
Post by hotdog067 »
i bought from an online store 20W-40 oil. It's cheap, maybe that's why its bubbling, (that's the reason why I want to try the additive first). will let u know how it goes...
They look to me nominal 25mm and 38mm x2mm normal orings
