How to replace cabin filter-with photos
stone36
Year and Model: 2005 V70R and XC90
Post by stone36 »
I replaced my cabin air filter today and took some pics, so here goes:
First remove the 2 torx bolts under the glove box (all the torx are T-25) Take that panel out, you have have to wiggle in from the carpeted paneling.
Unscrew the 4 T-25's on the black lid and remove black cover. The back two are a pain to get to because of the depth. I had to use a T-25 bit with a ratchet, but if you have a stubby t-25 (under 3 inches) it may fit.
Slide filter out, mine had a lot of crap that fell out with it so it was probably over due.
Installation is reverse, the filter will have a tab on it so you can't put it in backwards or upside down. Takes about 10-15 minutes.
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Funny that I just did this today on our V70...the screw location and everything else is exactly the same. Btw, I added this to the repair database.
-MIJ
That One Guy
Year and Model: 2001 S60 2.4T
Post by That One Guy »
I just did this for my 2001 S60, and it's the same procedure. I didn't use a genuine volvo filter, so there was no plastic tab to guarantee proper insertion. Just take note of how the old one was oriented.
dufferdude
Year and Model: 1995 T5R Tgul
Post by dufferdude »
How about the part number? TIA
1999 V70R #19 1995 T-5R #607
stone36
Post by stone36 »
Not sure about the part number, but they are easy to find at any auto store or through most of the links at the top of this page. That being said, if you are asking about a 98 V70R, it is in the engine compartment and a completely different (though just as easy if not easier) process. You'll want to look in the 850 v70 forum for that.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Hmm don't know how I missed this last year. Anyway, pinned in the Repair Database. Thanks Stone!
Also -> Amazon link
cincottamail
Year and Model: XC90 T6, 2003
Post by cincottamail »
Do you know the direction the arrows should face on the new filter? Should they face the engine or the cabin/seats?
Thanks
stone36
Post by stone36 »
If you have the OEM it has tabs that only allow it to go one way, but I can't remember which way the airflow goes, maybe someone has the VIDA and can post a PDF
rerobin66
Year and Model: 2000 S80 T6
Been thanked: 2 times
Post by rerobin66 »
fyi..there are two different thickness for the filter. and two slots in the chamber. the slot closest to the interior of cabin is thinner. the slot closest to the firewall is deeper and will accommodate a filter that is thicker.
1999 GMC Sierra
1964.5 Ford Mustang
2000 S80 T6
Vicious942
Year and Model: 2003 s80 T6
Post by Vicious942 »
Possible to update pictures?
