C30 Sputters at high RPM - No codes Topic is solved
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
nelaco
Year and Model: 2013 C30 R-Design
Has thanked: 7 times
Been thanked: 6 times
Post by nelaco »
Hi everyone. My son's '13 C30 with 64k miles started acting up about two weeks ago. Basically it sputters at high RPMs, mostly when changing gears at freeway speeds. I replaced:
FPS (Volvo) and made no difference
Coils (aftermarket) and seemed better for a day, but then it got worse and it sputters at idle as well.
Spark plugs (Volvo) are only 6 months old but I am about to replace them just in case.
The check engine light has not come on at all, and there are no codes.
I need to double check no vacuum hoses are cracked/disconnected, and fuel pressure at the rail in case it is the PEM.
Throttle body was cleaned also 6 months ago.
Can you think of anything else I should check?
Thank you everyone in advance!
2020 S60 T5
2013 C30 R-Design
2005 XC90 2.5T AWD
nelaco
Post by nelaco »
Update: I just used the scanner again and got Code P0299. I have a good TCV. I'll try to install it tomorrow.
2020 S60 T5
2013 C30 R-Design
2005 XC90 2.5T AWD
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Check for leaking Charge pipe, Intercooler ... anything along the path from Turbo to the head.
nelaco
Post by nelaco »
Thank you Rick, no leaks but I found the problem.
I had decided this morning to change the plugs just in case since I had ordered new ones from FCP. Plugs for #4 #5 had half their ground electrodes gone. First time this ever happened to me. I vacuumed, used a magnet, and cranked the engine without the plugs to make sure nothing was left in there. I used a scope camera to see if parts were still in the chamber, and to check the condition of the pistons. Thankfully they looked fine, but I could see where the piece had hit it a few times. I then did a compression test and got 165 all across.
I torqued the new ones to 21lbs. I installed the Volvo coils since obviously wasn't the problem.
Test drove it and it feels great again. P0299 is now gone.
Thank you again!
2020 S60 T5
2013 C30 R-Design
2005 XC90 2.5T AWD
