Hi everyone. My son's '13 C30 with 64k miles started acting up about two weeks ago. Basically it sputters at high RPMs, mostly when changing gears at freeway speeds. I replaced:
FPS (Volvo) and made no difference
Coils (aftermarket) and seemed better for a day, but then it got worse and it sputters at idle as well.
Spark plugs (Volvo) are only 6 months old but I am about to replace them just in case.
The check engine light has not come on at all, and there are no codes.
I need to double check no vacuum hoses are cracked/disconnected, and fuel pressure at the rail in case it is the PEM.
Throttle body was cleaned also 6 months ago.
Can you think of anything else I should check?
Thank you everyone in advance!
C30 Sputters at high RPM - No codes Topic is solved
- RickHaleParker
- Been thanked: 958 times
Check for leaking Charge pipe, Intercooler ... anything along the path from Turbo to the head.
nelaco
- Year and Model: 2013 C30 R-Design
- Has thanked: 7 times
- Been thanked: 6 times
Thank you Rick, no leaks but I found the problem.
I had decided this morning to change the plugs just in case since I had ordered new ones from FCP. Plugs for #4 #5 had half their ground electrodes gone. First time this ever happened to me. I vacuumed, used a magnet, and cranked the engine without the plugs to make sure nothing was left in there. I used a scope camera to see if parts were still in the chamber, and to check the condition of the pistons. Thankfully they looked fine, but I could see where the piece had hit it a few times. I then did a compression test and got 165 all across.
I torqued the new ones to 21lbs. I installed the Volvo coils since obviously wasn't the problem.
Test drove it and it feels great again. P0299 is now gone.
Thank you again!
Thank you again!
2020 S60 T5
2013 C30 R-Design
2005 XC90 2.5T AWD
2013 C30 R-Design
2005 XC90 2.5T AWD
