CAR BREAKING POTHOLE on Australian road, think it broke a suspension link or something, ive driven over many a pothole in my 98 V70 never broken anything, any idea what it sounds like you can hear it clunking when i turn the corner?
pothole breaks xc70 Topic is solved
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
- Has thanked: 1506 times
- Been thanked: 3819 times
I'll guess sway bar link. Strut seats are stronger than that, unless you used URO.
JRL
- Year and Model: Several
- Been thanked: 16 times
Not necessarily!
- Year and Model: Lots
- Been thanked: 128 times
URO now make excellent HD strut spring seats for Volvo with extra material in the hollow area that the early Volvo units were missing. They also use the newer XC90 part number for reference.
The lowest quality strut seats I've seen lately are Pro Parts. The design is the same as early 850s. They don't even SMELL like rubber.
My bet is on the spring seat also.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I'll also go with end link or broken spring (these are a bit fragile on the XC70)
keep us updated
keep us updated
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
If a sway bar breaks the two ends stay put. The only noise would have to come from the "broken ends" hitting together.
My money's on something else....possibly a spring.
The noise at 0:17 is interesting. Sounds like a blue tongued lizard wizard copping a walloping from the suspension bottoming out.
Get your hand scraper ready
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I say spring or end link. Spring seat would be one loud bang without all the clatter on the straightaway afterwards because the spring would still be under tension--just not as much. End link- if the top ball separated would get hung up against the wheel or shroud. If the end link came apart at the lower joint it would just hang there and probably not make all the noise afterward.
Can't rule out a LCA bush either. The flat round one if completely gone would result in the LCA banging against it's subframe mount from even minor road surface imperfections.
- 2325 Views
Last post by Clemens
- 1170 Views
Last post by callahanoffroad
