pothole breaks xc70 Topic is solved
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
CAR BREAKING POTHOLE on Australian road, think it broke a suspension link or something, ive driven over many a pothole in my 98 V70 never broken anything, any idea what it sounds like you can hear it clunking when i turn the corner?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
I'll say strut seat..
Been thanked: 4069 times
I'll guess sway bar link. Strut seats are stronger than that, unless you used URO.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Not necessarily!
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
URO now make excellent HD strut spring seats for Volvo with extra material in the hollow area that the early Volvo units were missing. They also use the newer XC90 part number for reference.
The lowest quality strut seats I've seen lately are Pro Parts. The design is the same as early 850s. They don't even SMELL like rubber.
My bet is on the spring seat also.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I'll also go with end link or broken spring (these are a bit fragile on the XC70)
keep us updated
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
If a sway bar breaks the two ends stay put. The only noise would have to come from the "broken ends" hitting together.
My money's on something else....possibly a spring.
The noise at 0:17 is interesting. Sounds like a blue tongued lizard wizard copping a walloping from the suspension bottoming out.
Get your hand scraper ready :D
jonesg
Post by jonesg »
First prize, all expenses paid trip to Ayers Rock, whether you want to go or not.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
I say spring or end link. Spring seat would be one loud bang without all the clatter on the straightaway afterwards because the spring would still be under tension--just not as much. End link- if the top ball separated would get hung up against the wheel or shroud. If the end link came apart at the lower joint it would just hang there and probably not make all the noise afterward.
Can't rule out a LCA bush either. The flat round one if completely gone would result in the LCA banging against it's subframe mount from even minor road surface imperfections.
