Only Drained 90oz Of Coolant Topic is solved
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Temperature Gauge / Sudden Low Battery Voltage
Post by Oka »
abscate wrote: 28 Sep 2020, 04:40 Did you use an OEM thermostat and sensor?
Aftermarkets have a high Failure rate Out of box (OBQ in QC-speak)
A genuine temperature sensor did it!
FAULTY TEMPERATURE GAUGE
Lucky for me, I ordered a genuine sensor last Friday and I got it Monday by noon. Yippie, for Anchorage, Alaska postage.
I could not wait to install the sensor. With he engine running. heat and fan at high, and filling the coolant, the gauge started rising. That was nice to see. Yesterday and today, drove it around the block with the coolant tank cap a little opened, I only refilled the tank when I got home. I went about two blocks. So, I would say, the temperature gauge is now working.
LOW BATTERY VOLTAGE
About the sudden low battery voltage, after replacing the CTS. I gave it a boost charge. It's been days now, no more issues. I don't know why it happened in the first place. Oh well, all is well in that front.
Thanks every one for all your inputs. Well appreciated!
Keep safe enough.
:D
Has thanked: 1505 times
Been thanked: 3818 times
Did we nail it? DO I get two sets of Volvo Horns this week??
Oka
Post by Oka »
abscate wrote: 06 Oct 2020, 14:44 Did we nail it? DO I get two sets of Volvo Horns this week??
Thank you!
:D :D :D
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
Oka wrote: 06 Oct 2020, 14:41
LOW BATTERY VOLTAGE
Keep safe enough.
:D
sometimes, when a component is missing from a circuit it turns something else on.
An example is when the door controller is unplugged , the footwell lights will not shut off and will run the battery down.
