Arose at 0530, coffee.
Uhaul at 0700 and picked up a f650 Uhaul
Loaded 4000 kg boxes
Followed a hot lady in a P2 to Port Jeff ferry
Arrived at new Volvo headquarters atv2000
Unloaded said boxes
Collapsed into bed with hot lady
Posted at 2206
Asleep at 2210
- Has thanked: 1507 times
- Been thanked: 3826 times
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Until there's photographic evidence of Volvos in a new driveway...
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
We have a 3d parts thread you can add this to. Great idea!Goupil wrote: ↑25 Mar 2023, 14:13Here you go, I might make a thread once they have survived a few thousand miles/months of use
https://www.thingiverse.com/thing:5931803
Still using the factory clips for the bottom edge, never had an issue with those and I have a lot spares since you cant buy the top ones separately![]()
viewtopic.php?t=98265
- Has thanked: 1855 times
- Been thanked: 1717 times
Quite the day abscate! Glad you both managed to survive the physical move. Now there are just a bunch of boxes to empty............!
So no actual car work, but I have updated the progress of the P80 speaker and audio test box progress in the Audio section. Now at the point of starting the wiring. Got the speaker mounts made and the banana plug sockets mounted. Next the actual wiring and making up a permanent head unit to speaker harness with banana plugs on the ends for easy connections.
Thanks again to Matthew for his help in getting my account back up and running. Took a lot of his time and patience! Much appreciated!
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 131 times
Funny how people are different. You're testing audio components, and I'm sitting here without the code even entered into my car stereo. I do know the antenna will go up and down, at least!scot850 wrote: ↑26 Mar 2023, 16:49 Quite the day abscate! Glad you both managed to survive the physical move. Now there are just a bunch of boxes to empty............!
I used my car today, to go to the local-history museum to drop off some donations.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
jsrnsis
- Year and Model: P80 enjoyer
- Has thanked: 25 times
- Been thanked: 68 times
Rear flexible brake lines on my 98 V70XC. 30 minute job turned into 12 hours of cursing the swedish. One side needed just a hacksaw and flaring tool, the driver's side needed the trailing arm/jack point to be dropped and absurd amount of bending for an 8 inch piece of brake line.
Old ones were rubbed through to the fiber, wanted to bleed the brakes anyways. Figured might as well while I'm in there, which seems to always be my problem.
Front ones came off with an Irwin 4LW and a little bit of weight, no problem.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
- Has thanked: 305 times
- Been thanked: 517 times
Those 4LW vise grips are awesome for brake lines. A must have tool for sure!jsrnsis wrote: ↑26 Mar 2023, 19:36 Rear flexible brake lines on my 98 V70XC. 30 minute job turned into 12 hours of cursing the swedish. One side needed just a hacksaw and flaring tool, the driver's side needed the trailing arm/jack point to be dropped and absurd amount of bending for an 8 inch piece of brake line.
jsrnsis
Yeah, I really wish I knew about them earlier, makes front brake lines a breeze. Too bad there's no room to turn them for the rear lines on an AWD p80.bmdubya1198 wrote: ↑26 Mar 2023, 19:54Those 4LW vise grips are awesome for brake lines. A must have tool for sure!
A snap-on 11mm flare wrench is seeming like it would be a smart purchase after stripping 3 Volvo flare nuts with the Harbor Freight Quinn set I have
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
I was able to use them on an AWD P80 rear brake line, but I removed that bracket just ahead of the rear wheel. It makes it a little easier. It looks like that bracket is supporting the subframe, but it's not.jsrnsis wrote: ↑26 Mar 2023, 21:22 Yeah, I really wish I knew about them earlier, makes front brake lines a breeze. Too bad there's no room to turn them for the rear lines on an AWD p80.
That probably wouldn't be a bad investment! Most cheaper line wrenches don't seem to fit very well on these soft little brake line fittings.
I went to the Snap On flare wrench years ago when I found all other brands I tried rounded the 11mm brake line flare nuts. On an AWD P80 it is not worth thinking about damaging a rear brake line as it means dropping the rear subframe to replace it.
