Has thanked: 1502 times
Been thanked: 3813 times
Arose at 0530, coffee.
Uhaul at 0700 and picked up a f650 Uhaul
Loaded 4000 kg boxes
Followed a hot lady in a P2 to Port Jeff ferry
Arrived at new Volvo headquarters atv2000
Unloaded said boxes
Collapsed into bed with hot lady
Posted at 2206
Asleep at 2210
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 25 Mar 2023, 20:07 Arose at 0530, coffee.
Unloaded said boxes
Posted at 2206
Asleep at 2210
Until there's photographic evidence of Volvos in a new driveway...
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Goupil wrote: 25 Mar 2023, 14:13
FireFox31 wrote: 25 Mar 2023, 13:01
Goupil wrote: 25 Mar 2023, 12:39 Made some 3d printed clips
Doesnt move at all now, worth having 4 visible screws :D
Great idea. Could you start a new thread and upload them there or to a public repository like Thingiverse? That would allow everyone access to this simple solution.
How are you securing the bottom edge of the tailgate?
Here you go, I might make a thread once they have survived a few thousand miles/months of use
https://www.thingiverse.com/thing:5931803
Still using the factory clips for the bottom edge, never had an issue with those and I have a lot spares since you cant buy the top ones separately :mrgreen:
We have a 3d parts thread you can add this to. Great idea!
viewtopic.php?t=98265
Has thanked: 1841 times
Been thanked: 1710 times
Quite the day abscate! Glad you both managed to survive the physical move. Now there are just a bunch of boxes to empty............!
So no actual car work, but I have updated the progress of the P80 speaker and audio test box progress in the Audio section. Now at the point of starting the wiring. Got the speaker mounts made and the banana plug sockets mounted. Next the actual wiring and making up a permanent head unit to speaker harness with banana plugs on the ends for easy connections.
Thanks again to Matthew for his help in getting my account back up and running. Took a lot of his time and patience! Much appreciated!
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 128 times
Post by 454cid »
scot850 wrote: 26 Mar 2023, 16:49 Quite the day abscate! Glad you both managed to survive the physical move. Now there are just a bunch of boxes to empty............!
Funny how people are different. You're testing audio components, and I'm sitting here without the code even entered into my car stereo. I do know the antenna will go up and down, at least! :D
I used my car today, to go to the local-history museum to drop off some donations.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
Rear flexible brake lines on my 98 V70XC. 30 minute job turned into 12 hours of cursing the swedish. One side needed just a hacksaw and flaring tool, the driver's side needed the trailing arm/jack point to be dropped and absurd amount of bending for an 8 inch piece of brake line.
Old ones were rubbed through to the fiber, wanted to bleed the brakes anyways. Figured might as well while I'm in there, which seems to always be my problem.
Front ones came off with an Irwin 4LW and a little bit of weight, no problem.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
jsrnsis wrote: 26 Mar 2023, 19:36 Rear flexible brake lines on my 98 V70XC. 30 minute job turned into 12 hours of cursing the swedish. One side needed just a hacksaw and flaring tool, the driver's side needed the trailing arm/jack point to be dropped and absurd amount of bending for an 8 inch piece of brake line.
Those 4LW vise grips are awesome for brake lines. A must have tool for sure!
jsrnsis
Post by jsrnsis »
bmdubya1198 wrote: 26 Mar 2023, 19:54Those 4LW vise grips are awesome for brake lines. A must have tool for sure!
Yeah, I really wish I knew about them earlier, makes front brake lines a breeze. Too bad there's no room to turn them for the rear lines on an AWD p80.
A snap-on 11mm flare wrench is seeming like it would be a smart purchase after stripping 3 Volvo flare nuts with the Harbor Freight Quinn set I have
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
bmdubya1198
jsrnsis wrote: 26 Mar 2023, 21:22 Yeah, I really wish I knew about them earlier, makes front brake lines a breeze. Too bad there's no room to turn them for the rear lines on an AWD p80.
I was able to use them on an AWD P80 rear brake line, but I removed that bracket just ahead of the rear wheel. It makes it a little easier. It looks like that bracket is supporting the subframe, but it's not.
That probably wouldn't be a bad investment! Most cheaper line wrenches don't seem to fit very well on these soft little brake line fittings.
I went to the Snap On flare wrench years ago when I found all other brands I tried rounded the 11mm brake line flare nuts. On an AWD P80 it is not worth thinking about damaging a rear brake line as it means dropping the rear subframe to replace it.
