jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
scot850 wrote: 10 Jul 2025, 11:26 And you are sure the parking brake cable is not binding?
Yes, I was going to remove the brake shoes to test, but the wheel spins much more freely with the brake pads removed, no rubbing sounds, the rotor comes right off without a struggle, and no evidence of the parking brake shoes getting glazed or worn down.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
850 LPT
Year and Model: 96' 850
Has thanked: 332 times
Been thanked: 243 times
Post by 850 LPT »
Replaced the fuel pump on the 98' S70 yesterday after confirming that there is no fuel pressure. The car still won't start. And yes, I dropped in another good pump relay before.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
850 LPT wrote: 12 Jul 2025, 15:10 Replaced the fuel pump on the 98' S70 yesterday after confirming that there is no fuel pressure. The car still won't start. And yes, I dropped in another good pump relay before.
Did you give the pump time to prime?
A full tank may help priming.
Chieber
Year and Model: 1998 v70
Has thanked: 45 times
Been thanked: 30 times
Post by Chieber »
Forgot to do the compression test with pedal to the metal.
Last time the test was taken an hour after a drive.
This time I had it idling for 10mins or so. Seems there’s not much difference between throttle open or closed.
Found out that at startup cilinder 4 is running real rich or there’s some seal leak, because the spark plug was greasy. After the compression test I drove around for a bit and parked the car. In the evening I pulled the greasy plug again and it was milky white again like the rest.
1/2 a shitbox V70 1998 2.5 NA
Has thanked: 1853 times
Been thanked: 1714 times
You may have a leaky injector or valve oil seals on that cylinder.
Has thanked: 1507 times
Been thanked: 3824 times
Another hour on Evita AC getting fittings off, but the Eagle has landed and it’s time to install shiny new parts and new Volvo bolts everywhere
viewtopic.php?t=106801
Worked on my single mum friend's much loved 98 V70 base. Car now has 130k miles on it. Still pretty low. She loves this car and it has a lot of maintenance from me and others over the years. Looking at the underside while up on the lift, the car has had good parts fitted due to free labor from me and low cost when my buddy the ex-Volvo mechanic is available.
Car has Bilstein shocks and struts, new coil springs at the front, donated slotted and vented front rotors and newish pads, and I have just replaced the rears with Brembo pads and rotors and aftermarket parking brake shoes.
A repair shop has also recently replaced the leaky steering rack and the inner and outer tie rods were done in the last year as well as the boots.
So all-in-all not a bad old car. The main issue was a clunking when been driven believed to be from the rear. Having checked everything that I think can be a source, I couldn't find anything and also checked the parking brake cables were free.
I did notice immediately a clunk, but not from the front as I was tidying up yesterday. My son was helping me set the parking brake and when he got out of the car and slammed the door closed, there it was! The infamous driver's door lower rear window guide clunk! Oh, joy..... :x
I fortunately had a used spare let in the stash so today I fitted it. Been a while since I last did one, but it turned out to be a real swine. Every task, even the simple ones fought every step. I even had the steel rivet by chance, but when I went to use my rivet gun it would not look at it. It has a steel center pin and it would not pull it and the handles started to bend. So I ended up substituting a small bolt nut and washer to keep it in place.
Anyway, after a lot of Engineering Technical words of encouragement it finally went pack together.
Well done, that man! Karmic deposits are always rewarded by the Creator.
I bought my third car off Capital but it’s a parts car , a high mile 1999 v70 wagon
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
^ If Abscate Breakers is in business, I'm still looking for a few parts for the V70 rebuild. Specifically the turn signal stalk and a cup holder ( of course ) if you have them.
1999 V70 GLT
Chieber
Post by Chieber »
scot850 wrote: 13 Jul 2025, 02:06 You may have a leaky injector or valve oil seals on that cylinder.
Reading through some topics on the valve oil seals, I think it’s that.
There’s some smoke on startup and when stationary at the lights.
The fumes from the exhaust also smells a bit burned. I’ll have to add that to the list of work to be done.
