Has thanked: 1507 times
Been thanked: 3825 times
Re: What did you do to your Volvo today? (now Sticky!!)
wizechatmgr wrote: 06 Apr 2018, 17:34
abscate wrote: 05 Apr 2018, 12:30 That’s a Rust free car up here....😀
Helped someone bleed air from brakes and gave an 8 year old her first impact wrench lesson
Next up, determining voltage threshold for a SIPS bag trigger
Give it the full 12V and it should blow. Or if you really want to make sure -- use a flyback transformer from a microwave -- it will go boom!
http://www.ti.com/lit/ds/slvsat2/slvsat2.pdf
Said 8 year old enjoyed the visit immensely.
Don’t forget to add both impact wrench and brake bleeding to her resume.
I gave her the bleeder cap and told her to find where it went, took about 10 seconds.
Inate mechanical ability, check
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
Hmm... just checked out a '98 XC that's making a grinding/groaning from the rear end under 10-15 mph. Debating on buying it, but I don't want to drain my wallet with the AWD. Plus there are other issues with the ABS module, PCV needs replacement, SAS code is present, passenger strut makes an awful clunking, and the passenger rear door needs to be replaced, it had an argument with another car.
Anybody know what the rear groaning is about?
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
bmdubya1198 wrote: 07 Apr 2018, 09:26 Hmm... just checked out a '98 XC that's making a grinding/groaning from the rear end under 10-15 mph. Debating on buying it, but I don't want to drain my wallet with the AWD. Plus there are other issues with the ABS module, PCV needs replacement, SAS code is present, passenger strut makes an awful clunking, and the passenger rear door needs to be replaced, it had an argument with another car.
Grinding could be brakes, wheel bearing or possibly rear propshaft but those are just places I'd look first based on your description. A rear groaning noise or humming sound while driving(could be mistaken for an exhaust leak) is usually a wheel bearing.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
bmdubya1198
shiloh51933 wrote: 07 Apr 2018, 10:04 Grinding could be brakes, wheel bearing or possibly rear propshaft but those are just places I'd look first based on your description. A rear groaning noise or humming sound while driving(could be mistaken for an exhaust leak) is usually a wheel bearing.
I'm almost certain it's AWD-related. Probably the diff or driveshaft. I don't think it's the brakes or wheel bearings. It's only when you start moving up until about 15 MPH.
Has thanked: 293 times
Been thanked: 766 times
Post by erikv11 »
brunocerous wrote: 06 Apr 2018, 17:48
erikv11 wrote: 01 Apr 2018, 21:20 Tightened the wiper blade nut on the T5-R. Again. Exhausting job, wiped me out.
About a month ago I noticed 3 out of 4 CV boots leaking grease on the 96 855, so I parked it. This weekend I finally got it into the garage and the axles pulled. Will try to chip away at re-booting them this week. One of the outers is still intact but I will just remove the outer CV's on both sides do all 4 of boots.
You inspired me to replace the door lock bushing! :)
Herculean! EPIC!!!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Checked, double checked and triple checked the status of recirc motor in ECC. Looks like I have to pull it apart. May do this Monday afternoon after the weekly sleep episode.
bmdubya1198
Got a really clean newer cam sensor from the junkyard today and TRIED to put it in, but I wasn't anticipating the previously stripped out screw to be so hard to remove. Maybe my Craftsman bolt-out socket will twist that thing off tomorrow. What a pain...
And I continue to wait for my 740 parts from FCP. The anticipation is killing me!
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
bmdubya1198 wrote: 04 Apr 2018, 17:56 Added a new Volvo to the collection yesterday. '88 740 Turbo M46. Needs some love, but it was $300, so I won't complain too much!
I'm a sucker for fixer-uppers. That's a beauty.
How did you find a 740 for $300?
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
Practice, practice, practice
bmdubya1198
brunocerous wrote: 10 Apr 2018, 18:59
I've perfected the art of buying sub-$500 cars over the past couple years :D
Found it on Offer Up, though. This is the first car I've bought outside of Craigslist.
