Has thanked: 1497 times
Been thanked: 3810 times
Re: What did you do to your Volvo today? (now Sticky!!)
Bruno , pack those counter holds with grease and then stick a large vacuum cap over them so they don’t corrode out. Four years from now you will thank yourself.
I had to grind off my OEM ones from 11.1998
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Man, am I glad I live in the south. There are plenty of things I don't like, but I sure love the lack of rust!
That’s a Rust free car up here....😀
Helped someone bleed air from brakes and gave an 8 year old her first impact wrench lesson
Next up, determining voltage threshold for a SIPS bag trigger
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
For years I was trying to chase down a vibration problem with my 98' V70 XC. Looked at everything from tires, cv axles, viscous coupler etc.
A couple of weeks ago I had my indie take out the prop shaft because I thought I might need a new one. When I picked up the car he said that the "torque tube bushing" had disintegrated and it should be replaced. I found the correct one at FCP and had him install it.
Yesterday I picked up the car and it is running super smooth again! So much fun.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
abscate wrote: 05 Apr 2018, 12:30 That’s a Rust free car up here....😀
Give it the full 12V and it should blow. Or if you really want to make sure -- use a flyback transformer from a microwave -- it will go boom!
http://www.ti.com/lit/ds/slvsat2/slvsat2.pdf
Said 8 year old enjoyed the visit immensely.
brunocerous
Year and Model: 1998 V70
Has thanked: 284 times
Been thanked: 36 times
Post by brunocerous »
erikv11 wrote: 01 Apr 2018, 21:20 Tightened the wiper blade nut on the T5-R. Again. Exhausting job, wiped me out.
About a month ago I noticed 3 out of 4 CV boots leaking grease on the 96 855, so I parked it. This weekend I finally got it into the garage and the axles pulled. Will try to chip away at re-booting them this week. One of the outers is still intact but I will just remove the outer CV's on both sides do all 4 of boots.
You inspired me to replace the door lock bushing! :)
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
brunocerous
abscate wrote: 05 Apr 2018, 04:55 Bruno , pack those counter holds with grease and then stick a large vacuum cap over them so they don’t corrode out. Four years from now you will thank yourself.
That's a great idea. Thanks! I'm also glad to hear that it wasn't just my bad luck with the end links. I'll remove rejoice if they last four years.
bmdubya1198 wrote: 05 Apr 2018, 08:01 Man, am I glad I live in the south. There are plenty of things I don't like, but I sure love the lack of rust!
What's crazy is that the shocks (SenSen) and the control arm (Mevotech) are maybe two months old!
I’m glad to see your strut nuts are on the right way. It’s uncomfortable having to adjust other people’s nuts And watch their strut.
bmdubya1198
abscate wrote: 07 Apr 2018, 04:43 I’m glad to see your strut nuts are on the right way. It’s uncomfortable having to adjust other people’s nuts And watch their strut.
Just about spit out my coffee reading that one... :lol:
MVS.... breakfast and a show
Bruno... bring that T30 up and we can cherry it, then twist it back, then play blacksmith and retemper o it back to a good tool.
We will burn at least $20 of acetylene doing that but it will be totally awesome
If it doesn’t work we will get a free replacement at Lowe’s, take pictures, and boast
