850 sedan 1994 Car will not start
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Try to start a car with maf sensor disconnected.If the car starts,that will confirm that problem is in maf.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
What about this?This also will stoping your car from a starting.Does it work?blueberry1 wrote:...The IAC no longer buzzes. It use to.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
volvomileage
- Year and Model:
do you get any spark, either from coil wire and or plugs ?
it might sound stupid but any power in the battery ? are your battery contacts clean and tight ?
as Lee had mentionned , you need power (elctricity) compression spark and fuel delivery to start the car...
lets recap ...new pump so constant fuel pressure, are the injectors working ?
any spark ?
best of luck..
any spark ?
best of luck..
volvo 850 95 sedan non/turbo 185 k
blueberry1
- Year and Model: 850 1994
Ok, after taking a brief hiatus from all of this, I have decided to continue and persevere with my efforts to get this swedish heap going. The good thing is that the more I work on it, the better I understand and respect it for what it is designed to do. I ave removed the idle air control valve ( IAC ) and cleaned it up by emmersing it in brakleen for a few minutes to loosen up all that carbon and gunk deposits and it now moves freely from end to end with a nice metallic clicking sound. A very satisfying and encouraging sound. I also took out the ignition coil connection and cleaned it up as well. Unfortunately my battery was dead so today I am going to attempt another start up after charging the battery back up. Fingers crossed and hope it all happens. I did attempt a start earlier and heard a series of clicks coming from the ignition coil and the IAC was buzzing as it should be. Encouraging sounds.....
blueberry1
Still nothing from all that. I think I'm gonna just get rid of it. Anyone interested in this car, I'm taking offers. It will have to be towed away.
- 10 Replies
- 684 Views
Last post by misha
- 1439 Views
Last post by 93Regina
- 2323 Views
Last post by julesV
- 1260 Views
Last post by anothersullivan
- 645 Views
Last post by RickHaleParker
