Hello All,
After a successful (and frustrating) timing belt chance I noticed something new. Oil is leaking from both the upper right corners of what I can best call the cam/valve cover. It's the piece of metal that separates the cam from the outer world. It's not the black cover, but the one underneath it.
I'm not sure what I did, but I've included some pics. Might it be a gasket after all?
Could it be oil being blown from the cyclinder one area of the valve cover to the cyclinder six area?
Thanks.
Lee
Post Timing Belt Blues (Valve Cover Leak?)
I checked the area near cyclinder 1 several times and noticed that an increasingly larger amount of oil was coming out.
I figured that I had nothing to loose by tightening the bolts, and it turns out that bolt nearest the leak was very loose. So it is possible that was the problem. Oil was being blown from cylinder 1 to cylinder six area after all. I hope that this cures it.
I couldn't find any parts number for a valve cover gasket on any site. So if anyone knows of a place let me know. It could be good practice just to replace it anyways.
I'll keep y'all updated.
Thanks,
Lee
Thanks,
Lee
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
Thanks for the advice. I saw that you are from Brunei. I head that it is very expensive to own a car there. Is that true? In American we consider car ownership an unspoken right. It takes a *lot* to have one's license revoked.
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Bill, thanks for the info.
To conclude this thread:
During my haste I accidentally loosened this bolt. It was loose enough for oil to escape under pressure.
I tightened the bolt to the same torque as the others. The leak at cylinder one is cured.
The leak near cylinder 6 was, in fact, oil being blown down the rail by wind.
Thanks to all for their help.
Lee
Lee
Many Thanks,
Bright
1995 960 Sedan
Bright
1995 960 Sedan
- billofdurham
Glad all turned out well. Thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 2943 Views
Last post by Clemens
- 295 Views
Last post by Twarr12000
- 14 Replies
- 7853 Views
Last post by RickHaleParker
- 829 Views
Last post by timetobakethedonuts
- 5506 Views
Last post by jimmy57
