Checking codes
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
Autozone will do it for you for free. The cheapest code readers go for around 50$. I saw some today in Home Depot and I assume they are also sold at other national chain hardware stores. Amazon.com has good prices. Once you have one, pry off the cover labeled "OBD II" under the liftable portion of the middle console, insert the cord that will come with the code reader into the port, and write down the code(s) you see. A list of what the codes mean can be found on volvospeed, are you can post it on the forum here and someone will know.
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
WHat year is your car? if it's 1995 or older it will have an obd 1 port under the hood that will give you the abitity to read your codes without an expensive code reader, 96 and up require an obd 2 code reader.
Search reading obd1 codes in this forum if your car is in the age bracket. I believe it's in the repair database. http://volvospeed.com/CheckEngine.php
Curtis
Curtis
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
My car is a '95. I just went out to read the codes.
Hole A1 was empty (nothing physically in the hole)
A2 was a 1-1-1
A3 was 2-1-1, 2-1-2, 2-1-3, 2-1-4, 1-4-1, 1-4-2
A5 was also physically empty
A6 was 1-1-1
A7 was 1-2-2, 1-1-3, 2-3-1
B1 was empty
B2 was 1-2-2
B5 was empty
B6 had no reading
A2 was a 1-1-1
A6 was 1-1-1
B1 was empty
B2 was 1-2-2
B5 was empty
B6 had no reading
A3 ABS
211- Left front wheel sensor, not signal on moving off
212-Right front wheel “
213-left rear wheel “
214-right rear wheel “
141- Faulty pedal sensor, shorted to ground or supply
142- Faulty brake pedal switch, open or short
A7
122- Temp. sensor interval too short
113-Fuel gauge open circuit
231-
So here is what I got from the readings. Would any of those error codes cause the car to not start? Also, why would my car ('95 volvo 850 glt) have nothing in holes A1 and A5?
A7
231-
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Clear all of the codes and then see which ones come back. Write those down and look in the repair database which has a list of what the codes mean. That will give you an idea of what might be wrong. If you need additional help don't hesitate to post back here.
- 843 Views
Last post by Ozark Lee
- 360 Views
Last post by Richiebuonanotte
- 881 Views
Last post by difflock54
- 3351 Views
Last post by pmondrian
- 9 Replies
- 1518 Views
