odometer/tripometer not working
roxen
Year and Model:
Post by roxen »
My ABS light started coming on and staying on a week or so ago, and I have come to the conclusion that it is caused by the ABS module going bad. But now my odometer and tripometer are not working either, and I can't imagine that they are related issues. It has to just be coincidence on the timing...but any idea what could be wrong with the odometer? If it is the cable is that something that can be fixed reliably outside the dealership at less cost? Thanks!!
Jot
Year and Model: C30 2010
Post by Jot »
Here is a link about the odometer gear. http://www.brickboard.com/AWD/index.htm ... show_all=1
roxen
Year and Model:
Post by roxen »
thanks Jot! we have to determine if that is what is the problem, but if it is that will help a lot!! we appreciate your time and the info!
Jot
Post by Jot »
Does the speedometer work OK ? If so it is the gear
roxen
Year and Model:
Post by roxen »
yes, the speedometer works fine. It is just the odometer and the tripometer that don't. Any idea how long of a job fixing it is if someone is fairly mechanically inclined? Could it be done on a Saturday? I can only imagine how much a dealer would charge to fix it!
Jot
Post by Jot »
go to www.volvospeed.com open repair/maintenance . scroll down to trim and you will find an article about the cluster removal
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2652 times
Been thanked: 1245 times
Post by matthew1 »
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Roxen, if you have the time/inclination to photograph the procedure, could you send me the pics? I'll make a How -To page.
Also -> Amazon link
roxen
Year and Model:
Post by roxen »
I would be happy to! I ordered the part so hopefully it will be here in a week or so. Just let me know what addy to email them to. Hopefully I will do it justice. I can't thank you and Jot enough for all your help!!
matthew1
Site Admin
Post by matthew1 »
[email protected]
Thanks in advance.
By the way, your name have anything to do with the server software Roxen?
http://www.roxen.com/products/webserver/
Also -> Amazon link
