crankshaft position sensor-
witek
Year and Model: 2000 volvo s70
Post by witek »
Hi could someone please please please tell me how I swap my bad crankshaft position sensor for my new and improved one? Thanks!!
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
It looks S/V70 has a different CPS configuration, (#10 in both pics):
For S/V70
For 850
You still need to take the cover off then unplug the sensor.
BTW, the part you got is 9202134 right?
http://www.eeuroparts.com/Main/PartDeta ... id=9202134
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
witek
Post by witek »
I want to thank everyone, and yep that is exactly the same part which confuses me because I was calling it a cam pos sensor and was to it was a crank pos in a previous posting.. Anyway, I am currently waiting in a garage for it to be finished. Again, thank you to all that wanted to help. God bless
richyoung
Year and Model: 2005 XC70
Post by richyoung »
Old post, but I think the answer is incorrect. I believe the original poster is correct that #10 is the cam position sensor. Sensor labeled #11 in the diagrams is the crankshaft position sensor. I just got back from the dealer parts counter where I checked their diagram and purchased the CPS for my XC70. My symptoms are the car intermittently cuts out while running. It "feels" like an ignition issue as it is very sudden and will correct itself. If at idle it will stall, but start back up immediately. I had a similar failure in an old '95 940 that was the same part.
richyoung
Post by richyoung »
Well, my problem was not fixed by the crankshaft position sensor. I found that the vehicle will run with the camshaft position sensor unplugged. After unplugging the "cutting out" did not appear. I am thinking that my camshaft sensor may have completely failed and is giving an intermittent erroneous signal that is causing the "cutting out" or stalling.
scgator62
Year and Model: c70 1999
Post by scgator62 »
I'm replacing my crankshaft position sensor. How do I get the plug in off the old one without damaging the connection. I have been jiggling and pulling with the limited space.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Clemens
Has thanked: 501 times
Been thanked: 228 times
Post by Clemens »
Brining up this old topic:
Who was OEM for the crank position sensor?
Thanks, Clemens
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
update: seems like VDO is OE. Can someone confirm that?
1996 855 R,
2010 V70 D5,
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
This post suggests VDO is the OE:
viewtopic.php?t=58548#p297548
I just bought a VDO (Continental) crankshaft sensor from FCP, who list it as OE, and there is a spot on the insulation about halfway down the cable that has been abraded away by hand. This is sometimes a sign that a part was originally branded with a car maker's brand name and is being sold on the aftermarket at a discount to the dealer price.
