How do I order the correct Timing Belt (94 850 non-turbo)?
RealityBytes
Year and Model: 850 1994
Post by RealityBytes »
First of all, I have to say I am extremely impressed and grateful for the how-to posts, especially the ones with pictures - thank you!
Now, as to my question:
When looking to order a t-belt for the 2.4L I5 (B5254S), I see three different ways of determining the appropriate belt, using a 6 or 7-digit engine number (not the 2-digit engine code, which is 55 of course!)
Here it says "Eng: -1266127, w/ Automatic Tensioner & w/o Direct Ignition" which seems to mean after Engine Number 1266127:
http://www.drivewire.com/vehicle/volvo- ... belt/#1994
But at the local parts stores, they specify a 6-DIGIT number; AutoZone and Advance say before/after 131034/131035 for a Dayco belt; whereas Barron's and Reilly's say before/after 131154/131155 for a Gates belt; this site shows both:
http://www.thepartsbin.com/catalog/?N=1 ... 63391+9318
This is, I suppose, more a matter of curiosity than need, as my timing cover shows both 7-digit "Artikel Nr. (P) 1289959" and 6-digit "Serie Nr. (T) 196933" numbers, both of which seem to be after the 'split'; but I just want to be sure.
Is 'Artikel Nr.' the part number, and 'Serie Nr.' the serial number? That would make sense, but why does DriveWire use the 7-digit number? And how can there be two different 'splits' in production, using the 6-digit number?
"Enquiring minds..."
Thanks!
-John
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The number in question is the engine serial number not the chassis number, it is normally on a sticker on the front of the timing belt cover.
RealityBytes
Lee,
I have found many of your posts to be helpful, but this one remains unclear to me.
I believe the "number in question" is the "engine number"; and indeed I too believe it is on the timing cover, as I stated - but I have two numbers there, one is a 6-digit number called "Serie Nr. (T)", the other is a 7-digit number called "Artikel Nr. (P)"; my question is WHICH ONE is the engine number?
(And now I'm more puzzled - is one of the numbers I mentioned, in my post, a chassis number?)
In any event, I still don't understand how 5 belt manufacturers can use 3 different numbers (one of which is 7-digits, the other two, 6-digits) to identify which part is used in that particular engine.
(In doing some reading here, I saw an oblique reference to "the infamous engine number" issue, but I tried to use search on this forum, and it says "Sorry but you cannot use search at this time. Please try again in a few minutes.".)
The mystery deepens...
Post by Ozark Lee »
I'm sorry, I didn't read your post well enough. Your car uses the later model belt. The number in question is indeed the Serie Nr.
RealityBytes
I'm still curious about the various manufacturers, but thanks for confirming I have the later model... I think it's a bit cheaper too!
-John
