water problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
barryallen501
Year and Model: 740 gle 1987
water problem
Post by barryallen501 »
i have a 1987 740gle non turbo. the water is back up thru the fill tank. and of course loosing water. now no heat. should i flush the system. i did put in a new radiator awhile back.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It sounds like you have a large air lock in the system.
When you replaced the radiator did you set the heater control to max heat before draining the system, leaving it there whilst refilling the system very slowly?
You may find the easiest solution is to drain the system into a container, with the heater set as above, so you can re-use the coolant then refill it, very slowly, occasionally massaging the two radiator hoses to help expel air.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
barryallen501
Thanks I will try this.
Reason: Reduced from all capital letters which signifies shouting.
