hello,
i recently bought a 99v70 xc awd as well and it is in the shop for the O2 sensor. I wanted to replace it myself but didn't get a solid answer about its location even with the pics. it is going to cost me 100 bucks to replace it...
anyway, my question is, is this car awd at all times or is there any button or something you choose to drive 2wd or awd like in the other trucks?
i have got the same seat problem, passenger side doesn't move. can you show us where that circuit breaker is?
thank you...
new owner 99 v70xc awd, tranny, power seat, reverse, other..
neworleans
- Year and Model: 2007 S60R
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
It is AWD at all times...it is mainly FWD biased as opposed to a truck or Jeep 4WD system, but it will transfer power to any wheel as necessary if others are slipping. The system on your '99 is purely mechanical as opposed to more sophisticated AWD systems out there now - make sure you change the bevel gear & trans. fluid and don't mix & match tires and it will be happy.
'98 S70 T5
2016 Chevy Cruze Premier
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
If the old AWD are anything like the new ones then its 95% power to front wheels and 5% to the back under normal driving conditions. The ratio changes as the situation calls for it. Also keep in mind that AWD means 4 wheel drive all the time, there is no choice of whether you turn it on or off. 4WD like on trucks, SUV's, etc, means you can choose between 2WD and 4WD.
KEWROCK
- Year and Model: V70R 1999
jablackburn wrote:It is AWD at all times...it is mainly FWD biased as opposed to a truck or Jeep 4WD system, but it will transfer power to any wheel as necessary if others are slipping. The system on your '99 is purely mechanical as opposed to more sophisticated AWD systems out there now - make sure you change the bevel gear & trans. fluid and don't mix & match tires and it will be happy.
How do I change the bevel fluid? I already changed the trans fluid. It made a world of difference. no more overdrive chatter and banging going into drive and reverse.
1999 V70R T5 AWD Red
jblackburn
Woot! I'm glad that worked!
Here's a great write-up someone else did on the bevel gear.
The document lists 1 liter of 1161648 Volvo fluid. You should use full synthetic 75W90 gear oil in it, which I'm pretty sure off the top of my head I remember seeing at Autozone or any store like that.
V70XCBevelGear.pdf- (229.74 KiB) Downloaded 244 times
'98 S70 T5
Regarding your cargo net, pull the net out of the wider seat back (right side) and pull on the driver's side of the rod. It will slide out and hook in the fitting above the window. Then pull the net out of the other seat back and you'll see that it hooks onto the exposed portion of the rod...........Re: AWD, my 2000 XC has a button behind the shifter marked with a "W". I believe it gives more positive traction to the rear wheels for icy road surfaces than in normal mode. I've had no use for this feature out here in Cali though but it looks like you'll be putting it to use this month.
@sorenmail thanks so much. I feel a little dumb not figuring that out but I am enlightened now. Can't wait to give it a try, though too cold to venture out again tonight.
BTW I made ample use of the W mode during the snow storm this weekend. Works great.
jblackburn
Just don't use W mode too much or you'll burn up your transmission
It starts the car off in 3rd gear, which helps you get started on hills without spinning tires, but it's hard on the torque converter. If you're not stuck, don't use it - mine will take off very well in snow with a light foot on the gas.
'98 S70 T5
- 1045 Views
Last post by matthew1
- 1976 Views
Last post by jblackburn
