Hi ...When I pull in my turn signal the high beams are on only as long as I keep it pulled in. Suspect relay. Has anyone had this problem and what was the solution.
Also the car jack that comes with it seems inadequate for the weight and stripped on the thread. Any recalls on these?
Thx
xc70 2003 High Beams just flash
Checksix
- Year and Model: V70 T5 2001
- Been thanked: 2 times
IF THE HEAD LIGHT SWITCH IS IN THE 9 O'CLOCK, position it will work as you just described. Place it in the 12:00 AND ALL WILL BE WELL.
I can't comment on the jack. Mine has worked perfectly the 2 times I've used it. Check at a salvage yard for a used one if your's is stripped. Wonder how THAT happened???
Jerry
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
- 13 Replies
- 3034 Views
Last post by oragex
- 1278 Views
Last post by chiefpontiac
