The thermocouple that indicates the outside temperature appears to show a break (broken circuit) at 32 degrees or below. It works fine until the temp drops below 32, at that point it acts like ther's a break in the circuit and the temperature indicator ramps up to 144 or so. With the car now thinking its 140 degrees outside, the climate control is wacked and the only way to get heat into the car is to set it at MAX. I don't know where this thermocuple is or what where it connects to, any ideas?
Frozen in Atlanta
S80 T6 2002 Outside Temp theromcouple fails at 32 = No Heat
