Speedometer cable
Speedometer cable
I have a 1990 Volvo 740 Turbo and I need to know two things: My Speedometer doesnt work but everything else on the dashboard does so I think I need a new cable. Is this a mechanical Speedometer or Electrical? Also where do I install it behind the dashboard or do I have to pull the transmission?
Your car has an electric speedo triggered from a "tone ring" or toothed wheel inside the differential. Your problem is probably either a dirty sensor, a faulty sensor or a damaged wire from the sensor to the speedo.
Rather that duplicate the effort here is a link that you will find useful
http://www.brickboard.com/FAQ/700-900/E ... uments.htm
- 11 Replies
- 4073 Views
Last post by gusinfantino
- 743 Views
