89 760T sunroof
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » Inability to Close Sunroof - 760
mtemart
Year and Model: 760t 1989
Volvo Repair Database 89 760T sunroof
Post by mtemart »
Hi tblo760,
Since you know a thing or 2 about sunroofs perhaps you can help me. I have a '89 760t wagon. In order to get my roof to close all the way I have to manually push that black spring loaded thingy down to get it to close all the way. Now, having done that, if the roof comes too far forward the rear right side of roof actually seems to collapse and leaves a large gap. I can power it back to the position where the margines around the sunroof and are the same. Any solution to this?
thanks marty
tblo760
Year and Model: 760 GLE 1987
Post by tblo760 »
I'll definately look into this for you.(just might take a few hours).1st let me know if it's factory fitted unit,a metal or glass lid,and what's the thingy made of? has it ever worked ok? Terry.
The way of the wicked is as darkness,they know not at what they stumble,(That's why I'm here to help)
mtemart
Post by mtemart »
Hi,
It is a factory original, metal, and the piece that I have to hold down in order for the roof to completely close stretches from side rail to side rail and it appears as if the rollers on the actual sunroof are supposed to suppress the guard and push it down in order for it to close properly. I'll see if i can locate the exact name for what I am calling a thingy.
thanks
marty
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Wind deflector? :mrgreen:
I'm going to split this off into the RWD section for you guys. I'll PM you both a link to it.
'98 S70 T5
2016 Chevy Cruze Premier
tblo760
Post by tblo760 »
mtemart wrote:Hi,
thanks
marty
If it's the wind deflector,(blackplastic "thingy" at the front) then this is a common fault,take it off all together and see the result.There is a repair that you can make,fix a small piece of metal or stiff plastic about half way along 1 of the thin rods to stop it lifting all the way up.I'll try and draw it up,and post it.
mtemart
Post by mtemart »
Thank you so very muchly...
marty
tblo760
Post by tblo760 »
mtemart wrote:Hi,
thanks
marty
Ok.Marty,I've had this on every 700,the small operating rods are just not strong enough to survive,and the wind deflector is not closing quick enough before the lid shuts.You can do without it if you wish,if not,then just follow the instructions in the 'scetch'
the black thingy
the black thingy
talbott357
Year and Model: 1988 740, 1989 760
Post by talbott357 »
Both my 88 740 and my 94 940 do the same thing, I just taped it down and live with it. Its a volvo thing.
mtemart
Post by mtemart »
Thanks to everyone for the solution to the "wind thingy".
However, this seemed to be the least of my roofy problems. As I was examining the rest of my sunroof I noticed some leakage, (actually while giving it a very over-due wash), and that one side of roof was lower than the other.(See previous and newer postings).
So, after all was said and done, I ended up going to the j/y and getting a complete roof unit, including track, for $48. First thing I did was, as advised, was rip the "wind-thingy" totally off of replacement roof!!
