960 3ltr 1994 rear coil spring replacement
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
father ted
Year and Model:
Post by father ted »
Haveing aquired new rear coil springs for my multilink suspension fitted 960 i am now wondering if there are any pitfalls to look out for during fitting. Can i lift the whole back end up and fit them both together or one side at a time. I am aware of the brake pipes restricting movement but is there anything else i should be aware of. Any help is appreciated.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The attached should help. You can do both sides together but note the part about disconnecting the drive shaft.
960 rear coil springs1.pdf
(217.52 KiB) Downloaded 125 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
father ted
Year and Model:
Thanks Bill, spot on! everything i needed to know.
