Group:
My '01 S602.4T power steering fluid reservoir has been leaking since the car was out of warranty due to time. It currently has only 64K miles on it. Was there a recall or TSB on this problem?
I try to avoid the dealer as much as possible.
It is a fairly early model purchased in March of '01.
A bit of PS fluid now and then is much cheaper than changing the reservoir or removing it to see why it leaks. Actually it seems to leak around the cap.
It is not overfilled.
TIA for any advice.
Sixvolvos
Leaking PS Fluid Reservoir
E170_Driver
- Year and Model: bye V70 2.4T, 2001
I am glad someone else brought up this problem; I have exactly the same issue on my V70. I looked at the cap, the reservoir and the lines, but all seems good. I recently refilled a little fluid to bring it back up to par, but am puzzled where the leak is. I will post pictures when I get back from my trip; maybe it is the cap, just don't know what else it could be. Quite the mess around the top of the reservoir though.
Jan
Jan
Former 2001 V70 2.4T owner
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Hello, A suction line on my V70 had a SMALL leak at the reservoir outlet barb. Maybe a loose hose clamp or razor blade cut from a previous hose removal. It drew air and caused the fluid to foam. The foam expanded out the top of the reservoir alot. That leakage from above covered any evidence of leakage at the reservoirs' bottom. Try tightening clamps, adding a wrap of teflon tape. My suction line had turned into a soft ratty mess so I replaced it. Kira
OEMVolvoParts
- Year and Model: ALL
To fix this problem you need to buy a new cap. The gasket is not available seperately, it will come with the new cap. Part number is 9475862, just put the part number into our search bar.
E170_Driver
Here is a picture of the PS reservoir with the leak...
...and the culprit is definitely the cap. The green seal under cap just goes bad...
In the process of ordering a new one...meanwhile I just put a bunch of electrical tape on top of the seal to tighten the fit.
Jan
Jan
Checksix
- Year and Model: V70 T5 2001
- Been thanked: 2 times
Can you pull the seal and put the tape (spacer) on the other side, to add the additional height needed to get a good seal? I'm beginning to experience similar indications.
Jerry
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
E170_Driver
I tried to work on removing the seal and turning it around; no avail without damaging the cap. Once I get my new cap I will try taking it apart.
Jan
Jan
OEMVolvoParts
Call me crazy but I might not put small pieces of electrical tape on top of that cap. If they fall off where do they go? I would deal with the leak until you get a new cap.
E170_Driver
You are not crazy and thanks for the headsup...reason why I am on this forum...to learn. Little thingies coming right off.
Thanks Parts Guy...
Jan
Thanks Parts Guy...
Jan
- 7524 Views
Last post by jadnhm
- 13 Replies
- 2821 Views
Last post by bmdubya1198
- 2040 Views
Last post by oragex
- 4492 Views
Last post by eyerollXC70
- 2297 Views
Last post by MadeInJapan
