V40 1.9 oil pan - sump replacement
1996 - 2004 S40
1996 - 2004 V40
jgillmor
Year and Model: v40 1999 & 2002
Post by jgillmor »
Hi there, My wife did it again and tore a 4 cm hole in sump of 2002 TD. I've removed all 20 wee 'star' head bolts, and the two large (14mm ?) going horizontally into the rising, pasanger side of the sump. I tried to be gentle, but ended up prising the sump down by approx 2 cm on driver side with (gentle!) chisel... but passanger side of sump not coming away. Is there a bolt I missed, or is it just the old gasket that I have been unable to cut or force apart ?
Any tips on completing the replacement, and other jobs I should consider (I will keep the day job !!) when the sump is off. Thanks a million - great site !!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You have removed 20 torx screws. The Volvo parts list says there are 21 and the attached diagram for removing the sump has 22. However, the diagram also shows 4 other bolts holding it in on the gearbox side. So you have 2 more to find.
V40 sump removal.pdf
(227.05 KiB) Downloaded 445 times
The diagram refers to bolts A and B and did have a guide as to which they are but my printer cut it off. The heavy arrows are A and the light arrows are B.
I can't think of anything else you should tackle with the sump off, unless you are having problems with oil circulation apart, that is, from having no oil to circulate due to a hole in the sump. I am a great believer in the saying, "If it isn't broke, don't mend it."
Good luck and keep us updated.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jgillmor
Post by jgillmor »
Good man Bill - very grateful for diagram... I had actually missed the four screws under the engine mount.. easy when you know how !! Replaced sump with old one (€160 versus €550 new) and used small amount of sealent below and above rubber seal, and a skim on the block. No leaks so far, and the missus thinks I can fix cars.. again!! I was nervous about working under proped car and jacked engine, but it all turned out very stable.
Great site and thanks again!
billofdurham
You are welcome. Thank you for the update.
Bill.
Previously:
