Hi there, My wife did it again and tore a 4 cm hole in sump of 2002 TD. I've removed all 20 wee 'star' head bolts, and the two large (14mm ?) going horizontally into the rising, pasanger side of the sump. I tried to be gentle, but ended up prising the sump down by approx 2 cm on driver side with (gentle!) chisel... but passanger side of sump not coming away. Is there a bolt I missed, or is it just the old gasket that I have been unable to cut or force apart ?
Any tips on completing the replacement, and other jobs I should consider (I will keep the day job !!) when the sump is off. Thanks a million - great site !!
V40 1.9 oil pan - sump replacement
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
You have removed 20 torx screws. The Volvo parts list says there are 21 and the attached diagram for removing the sump has 22. However, the diagram also shows 4 other bolts holding it in on the gearbox side. So you have 2 more to find.
The diagram refers to bolts A and B and did have a guide as to which they are but my printer cut it off. The heavy arrows are A and the light arrows are B.
I can't think of anything else you should tackle with the sump off, unless you are having problems with oil circulation apart, that is, from having no oil to circulate due to a hole in the sump. I am a great believer in the saying, "If it isn't broke, don't mend it."
Good luck and keep us updated.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Good man Bill - very grateful for diagram... I had actually missed the four screws under the engine mount.. easy when you know how !! Replaced sump with old one (€160 versus €550 new) and used small amount of sealent below and above rubber seal, and a skim on the block. No leaks so far, and the missus thinks I can fix cars.. again!! I was nervous about working under proped car and jacked engine, but it all turned out very stable.
Great site and thanks again!
- billofdurham
You are welcome. Thank you for the update.
Bill.
Bill.
Previously:
Previously:
- 986 Views
Last post by theWIFES_S70
- 1513 Views
Last post by jamadams
