P0011 Engine Code - camshaft sensor - timing advance
sxd123
Year and Model: 2004 V70
Post by sxd123 »
I've got this code intermittently the last 3 months. Has anyone had this. Doesn't seem to affect engine performance. And the cure? replace sensor. mechanic has told me that mechanic forum says contaminated oil could be the culprit here.
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Hello, How many miles are on your car? Kira
JDS60R
Been thanked: 3 times
Post by JDS60R »
A friend is dealing with this same issue. We pulled the solenoid and found some sludge in one of the oil galleys. Clenaed it and replaced it with the new gasket which has a filter in. His is an 02 S60 N/A. The code is now very infrequent. The engine light comes on and then goes off. We will clean the solenoid next time and if not a complete fix we will replace the VVT solenoid.
Wish I had an answer for you but this is where we are at right now.
Retired
sxd123
Post by sxd123 »
85000 km(53000 miles)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Here's a bit of reading for you:
https://www.matthewsvolvosite.com/forums ... =1&t=21162
https://www.matthewsvolvosite.com/forums ... 3&p=117648
And finally, the replacement procedure:
The solenoid replacement should be almost, if not exactly identical on your S60 as ecb's XC70 if you choose to go about it yourself.
'98 S70 T5
2016 Chevy Cruze Premier
