Ignition key cylinder
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
shelly4278
Year and Model: s40 2005
Post by shelly4278 »
I was told that I need a need a ignition key cylinder. That cost about $585.00. Is there a cheaper way to fix this problem. They is getting stuck in the ignition.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
shelly4278 wrote:I was told that I need a need a ignition key cylinder. That cost about $585.00. Is there a cheaper way to fix this problem. They is getting stuck in the ignition.
Did you try squirting some WD40 in the cylinder opening?
