My 1992 Volvo 940 Turbo is making me nervous.
She just stopped on the street and it seemed all the dashboard warning lights went on
Tow truck guy thought it might be a fuel pump???
I need to move her today and would dearly appreciate some quick advice.
Thanks,
Paul
card just died dashboard warn lights like Xmas
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
When the engine dies all of the dash lights will come on as the ignition is still on.
Usually when a fuel pump goes the engine will splutter to a halt as the fuel supply is used up. If it just stopped I would suspect the timing belt has snapped. This is easy to check by removing the top section of the timing belt cover.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Paul ..just take off the oil fill cap and crank the engine and see if the cam spins,fuel pump relays also go bad pull the ash tray and feel the white relay it should "click" when cranking the engine
Dick K. from FLA ..aka volvofix1
- 1064 Views
Last post by polskamafia mjl
- 13 Replies
- 4001 Views
Last post by gswede
