HELP!!!
cajun95t850
Year and Model:
HELP!!!
Post by cajun95t850 »
I have pulled off some DTC codes off of my volvo 1995 850t and i don't know what they are
A-2 414 and 232
A-3 142
B-1 325
B-2 122
HELP ME PLEASE
kelvin6
Year and Model:
Post by kelvin6 »
Assuming that you read the codes correctly: (I'm reading this off the Chilton Manual)
A2 414: Boost Pressure Regulation.
232: Long Term Fuel Trim, idling
A3 142: (doesn't appear in the manual :? ?)
B1 325: Memory Failure
B2 122: (doesn't appear in the manual :? ?)
Your car might have that OBDII port (hidden under the coin holder), i'm not sure if it is functional (I found conflicting data) on the 95 turbo model, but I know it is for the non-turbo. If you can obtain (borrow) a reader (that can do ISO-9141 standard) you maybe able to read codes off the car a little better.
1998 Volvo S70 T5 Auto
1995 Volvo 850 GLT <- RIP
rp850
Year and Model:
Post by rp850 »
A3 142 Faulty brake pedal switch, open or short
Auto Zone will read OBD-II codes for free.
I have a 95 turbo with OBD-I under the hood AND the OBD-II port. The OBD-II port does not return codes when the reader is attached though. I get all the diagnostic info from under the hood.
kelvin6 wrote:Assuming that you read the codes correctly: (I'm reading this off the Chilton Manual)
