2000 V70 AC recharging
Locked
sszewczuk
Year and Model: v70 2000
Post by sszewczuk »
Does anyone on what side to charge the AC on a 2000 v70SE?
I only see one port. How does it open- unscrew? pull?
Do I charge it with the car running or not?
etc.....
Please help
Yes, I know-- bring it to a certified repair place------- but hell, I'd rather try it myself first
850tech
Year and Model: 1995 850 Turbo 5spd
Post by 850tech »
Car running A/C on, and the port you see is the only port on these systems. Take the cap off and install the line that came with your A/C kit on (if you don't have the line you'll need it) then attach the other side to the can of R134a. The line should have a piercing valve on the can side, screw that all the way in, then all the way out. Hang the can upside down and wait for it to get nice and cool, once its cold remove to can.
sszewczuk
Post by sszewczuk »
850tech wrote:Car running A/C on, and the port you see is the only port on these systems. Take the cap off and install the line that came with your A/C kit on (if you don't have the line you'll need it) then attach the other side to the can of R134a. The line should have a piercing valve on the can side, screw that all the way in, then all the way out. Hang the can upside down and wait for it to get nice and cool, once its cold remove to can.
hey thanks for the info
is that the port with the 6Nm on the cap?
how do you remove it?
850tech
Post by 850tech »
Yes, just unscrew it, counter clockwise.
sszewczuk
Post by sszewczuk »
I did everything as stated but the refridgerant would not empty into the system. I shook the can like I was jerking off the car (lol) but it didnt work. Did it for like 15 minutes. Nothing.
I took it off the port--- pressed the button and shook the can and all seemed ok but it would not empty into the system?????
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Are you sure it's not already full? What's the actual issue with the AC?
Some people say the trick is to put the can in warm water while emptying it, so it doesn't freeze up.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
sszewczuk
Post by sszewczuk »
ecbsykes wrote:Are you sure it's not already full? What's the actual issue with the AC?
Problem is it blows cold for like 2 minutes and then gets warm.
The can wasnt freezing up--- it wasnt even going in from what I could tell.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Put the can of R134 in a bucket of WARM water, it WILL flow in, (full or not)!!!
sszewczuk
Post by sszewczuk »
JRL wrote:Put the can of R134 in a bucket of WARM water, it WILL flow in, (full or not)!!!
I will try again later today- but I dont see how that will work?
sszewczuk
Post by sszewczuk »
OK, the system has the 2lb of R134 needed. It works for a while then continues to blow but blows warm, so I guess the compressor shuts off----- why would this happen?
Locked
