Out side temperature readings
pman7373
Year and Model: s70 GLT SE 2000
Post by pman7373 »
Hey Guys,
The reading on my car is normally hotter than the temperature out side. Sometimes its marginal and stays that way. Sometimes it's ridiculous. Last week I was in a parking lot of traffic for about 2 hours and my temperature was like 50-60 degrees hotter than outside. Is this something i should worry about or is this more just the thermostat is placed near the engine or compressor? My car temp gauge always goes to the normal place after the car has sufficiently warmed up.
Thanks!
2000 S70 GLT SE Turbo 109,000 miles
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
If you keep the car in once place for a long time with the engine on, the air around the thermometer gets heated to much higher than the abient air temp. It's just b/c the thermometer is so close to the engine. While driving you have fresh air being continually blown past the thermo so it reads the true ambient air temp.
pman7373
Post by pman7373 »
Thanks! I wish it was in a different place!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Mine regularly shows 117 or something stupid when it's 90 degrees outside. The temperature sensors are located under the bumper behind the fog light grille - I think it's time we both need new ones :mrgreen:
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Make sure your sensor hasn't gotten dislodged from it's mount. When they do, sometimes they end up sitting on or next to the radiator, which obviously explains the silly reading. Look under the car, up near the intercooler and plastic splash guard thing. You should be able to see the sensor sticking out, or if it's not there, there will be a hole where it should plug in to.
But I wouldn't worry about it too much. Mine are set up correctly and even so, I'll still get ridiculous readings when sitting. Once you get moving though, the airflow should make the temperature more or less accurate.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
adk793
Year and Model: 2000 V70 XC AWD/SE
Post by adk793 »
yeah, the sensor picks up the heat from around the engine, but for me, once i get on the highway n get driving for like 5 minutes, it would usually give an accurate reading but then even when i stop for a few minutes, it starts jumping up slightly. Out of all the issues i have with the car, this is one i can literally care less about
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Fact:
The temp gauge reads between 2 to 4 degress hotter than the actual temp.(Gen 1s)
Fact:
When you're parked/stopped (in the summer) the gauge will go higher
Fact:
If the temp reading doesn't come back to normal after a mile or two of driving at speed, the gauge got dislodged or you need a new one
