Hey Guys,
The reading on my car is normally hotter than the temperature out side. Sometimes its marginal and stays that way. Sometimes it's ridiculous. Last week I was in a parking lot of traffic for about 2 hours and my temperature was like 50-60 degrees hotter than outside. Is this something i should worry about or is this more just the thermostat is placed near the engine or compressor? My car temp gauge always goes to the normal place after the car has sufficiently warmed up.
Thanks!
Out side temperature readings
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
If you keep the car in once place for a long time with the engine on, the air around the thermometer gets heated to much higher than the abient air temp. It's just b/c the thermometer is so close to the engine. While driving you have fresh air being continually blown past the thermo so it reads the true ambient air temp.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Mine regularly shows 117 or something stupid when it's 90 degrees outside. The temperature sensors are located under the bumper behind the fog light grille - I think it's time we both need new ones
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Make sure your sensor hasn't gotten dislodged from it's mount. When they do, sometimes they end up sitting on or next to the radiator, which obviously explains the silly reading. Look under the car, up near the intercooler and plastic splash guard thing. You should be able to see the sensor sticking out, or if it's not there, there will be a hole where it should plug in to.
But I wouldn't worry about it too much. Mine are set up correctly and even so, I'll still get ridiculous readings when sitting. Once you get moving though, the airflow should make the temperature more or less accurate.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
adk793
- Year and Model: 2000 V70 XC AWD/SE
yeah, the sensor picks up the heat from around the engine, but for me, once i get on the highway n get driving for like 5 minutes, it would usually give an accurate reading but then even when i stop for a few minutes, it starts jumping up slightly. Out of all the issues i have with the car, this is one i can literally care less about
JRL
- Year and Model: Several
- Been thanked: 16 times
Fact:
The temp gauge reads between 2 to 4 degress hotter than the actual temp.(Gen 1s)
Fact:
When you're parked/stopped (in the summer) the gauge will go higher
Fact:
If the temp reading doesn't come back to normal after a mile or two of driving at speed, the gauge got dislodged or you need a new one
Fact:
Fact:
