1993-1997 Volvo 850 ACC Cabin Temperature Sensor location.
marginal
Year and Model: V70 D5 2003
Post by marginal »
Hello everyone.
Would anyone happen to know where exactly is located the 1993-1997 Volvo 850 ACC Cabin Temperature Sensor and how it is possible to reach it?
Here it is:
http://www.fcpgroton.com/product-exec/p ... ure+Sensor
Thank you in advance :) ...
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Behind each of the grab bars above the door. There is a little vent than can be pried off with a screwdriver. I would take a picture, but my S70 doesn't have them there.
Take a can of compressed air (or a shop vac on the blowing side) and blow out each of the sensors before you go about ordering new ones, and they may still work just fine :)
'98 S70 T5
2016 Chevy Cruze Premier
marginal
Post by marginal »
Hi jablackburn and thank you for answering.
Do you mean here, where the black arrow is pointing to?
jblackburn
Thats it!
'98 S70 T5
marginal
Post by marginal »
I'll check it out.
Thanks.
markyoung
Year and Model: 2004 Volvo V40
Post by markyoung »
jablackburn wrote:Thats it!
is that cabin is the same with A/C ACC Temperature Sensor? i am a bit confused with this too. Are they different? Sorry for asking questions like this but i really have no idea.
jblackburn
The temp sensor on a V40 is integrated into the climate control module in the dash itself. Look for a little vent that you can blow out with a can of compressed air.
If that doesn't work and the sensor is bad, the entire module needs to be replaced (head to a junkyard/used parts site!)
v40 climate control panel.jpg (105.61 KiB) Viewed 5073 times
'98 S70 T5
kiss4afrog
Year and Model: 850 1995
Post by kiss4afrog »
marginal wrote:Hello everyone.
Here it is:
There is a problem with the question in that yes there are sensors in the grab handles above the front doors but there is also a sensor in the plenum near the blower motor and also one in with the red light on the dashboard for sun load. So there is four I know of on my 850.
You can never have too big a Turbo !
hanzbe420
Year and Model: 2006 s60 2.5T
Post by hanzbe420 »
hi the spring fell out of my sensor! If u look at the pic here,
is there anyway i can just put it back in? it didn't look broken. Just looked like it fell out.. Here is my post about it. please answer there if u can, because my blower motor stopped working and gave a power stage code then 1 day it just turned on but still flashing the lights. so i looked up the code and got 124 and 126 interior temp sensors. But my question is, If the powerstage died and threw a code, how come it is working now? And why did the sensors go? My blower motor makes allot of noise and needs to be changed would this cause resistance and blow the sensor maybe? But i can't clear these codes. It says i clear them but then i press it right after and the code is there so im wondering if i should just go to the junkyard get a blower motor and 2 temp sensors, even know i think its just the driver's side that broke cause thats where the spring fell out. plz help!
flatogen
Year and Model: 1994 850
Post by flatogen »
hanzbe420 wrote:hi the spring fell out of my sensor...
That's not a spring. That is the thermistor, the heart of the sensor. It looks like a spring because the leads, the wires connected to it, are coiled so as to have a lot of contact with the air being sucked by it.
Mine also fell out, but I can't find it. I need to get a 10k ohm NTC thermistor and solder it in. See this thread:
http://www.volvoforums.org.uk/archive/i ... 22093.html
But I don't know how to get the assembly out yet. Anyone?
