Any insight on this?
Cruise Control 1998 V70XC
My cruise control does not function at all. I've heard this might be a vacuum line under the battery that could be the culprit?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
That is one of the most common failure points. The brake switch is also a common failure item up under the dash - mine needed a bit of adjusting just to make my shifter work, but I'd start with the line under battery. To get it out, undo the clip and then shove the battery to the side and it will lift out.
'98 S70 T5
2016 Chevy Cruze Premier
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
It's also worth keeping in mind that if you have a hosed ABS module,
all of your speed signal related equipment will be affected.
Any ABS or TRACS lights? Does your speedo/ODO work?
Just checkin'...
If any of this sounds familiar, read up here for more info:
http://home.earthlink.net/~vicrocha/
Just checkin'...
- Been thanked: 466 times
In my case, the vacuum was fine but the switch needed adjustment.
My "lazy" way: get a pair of pliers and gently bend the bracket holding the brake switch (the switch with vacuum hose) downward a tiny bit. This fixed my problems.
shermy
- Year and Model: 1998 volvo v70xc
how does one test the components once you find them.
found and looked at the one under the battery, and then ?
found and looked at the solenoid coming off the throttle, and then?
found and looked at vacuum servo, and then?
shermy
where is the break position switch, out in the engine compartment? passenger compartment foot pedal?cn90 wrote:In my case, the vacuum was fine but the switch needed adjustment.
