Cruise Control 1998 V70XC
Mauiman
Year and Model: 1998 V70XC
Post by Mauiman »
My cruise control does not function at all. I've heard this might be a vacuum line under the battery that could be the culprit?
Any insight on this? :?:
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
That is one of the most common failure points. The brake switch is also a common failure item up under the dash - mine needed a bit of adjusting just to make my shifter work, but I'd start with the line under battery. To get it out, undo the clip and then shove the battery to the side and it will lift out.
'98 S70 T5
2016 Chevy Cruze Premier
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
It's also worth keeping in mind that if you have a hosed ABS module,
all of your speed signal related equipment will be affected.
Any ABS or TRACS lights? Does your speedo/ODO work?
Just checkin'... :wink:
If any of this sounds familiar, read up here for more info:
http://home.earthlink.net/~vicrocha/
Mauiman
Post by Mauiman »
No apparent ABS or TRACS light problems. My speedometer/ODO do work.
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
In my case, the vacuum was fine but the switch needed adjustment.
My "lazy" way: get a pair of pliers and gently bend the bracket holding the brake switch (the switch with vacuum hose) downward a tiny bit. This fixed my problems.
shermy
Year and Model: 1998 volvo v70xc
Post by shermy »
how does one test the components once you find them.
found and looked at the one under the battery, and then ?
found and looked at the solenoid coming off the throttle, and then?
found and looked at vacuum servo, and then?
shermy
Post by shermy »
cn90 wrote:In my case, the vacuum was fine but the switch needed adjustment.
where is the break position switch, out in the engine compartment? passenger compartment foot pedal?
