05' V70 Fuel gauge stuck full
Jack Ryan
Year and Model: V70 2005
Post by Jack Ryan »
I have a 2005 US V70 75,000miles and the message center is showing the "miles til empty" climbing and the fuel gauge reading full. I put 17.73 gallons in and still reading full. I haven't done any work besides lube and filter. My other concern is if I pull the sender how are Volvo fuel pumps? In your opinion should I bite the bullet and install one? BTW can I do it without dropping the tank?
Thanks in advance.
7/27/10
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Fuel pump has nothing to do with the fuel sender.
Try to get close to the top of the tank next to the fuel sender (if possible) and give it a tap with a hammer (seriously) it may just be stuck
Jack Ryan
Post by Jack Ryan »
I'll try to get some time on the lift this weekend and try that while checking harness.
thanks. Do you know if the tank needs to be pulled for pulling pump?
igel513
Year and Model: 2003 S60 T5
Post by igel513 »
The fuel sender should be under the back seat. Pull up the seat, unfold the carpet and u'll see a round plate - access window- w/ 4 10 mm bolts. U don't have to pull d tank down.
Jack Ryan
Post by Jack Ryan »
Thanks I give it a try. I work on trucks and usually if pulling the sender the pump is right there. This is great news. I think I found a great site here and hope to be able to help someone else in the future. I post what I find.
Thanx
Ringsing
Year and Model: S80D5 2006
Post by Ringsing »
Hi Jack,
Can I ask you if you had your fuel gauge issue sorted out ?
I've got an '06 S80 with a similar problem. My local Volvo garage here in UK have just called and said they will charge me at least $400 to have it sorted.
Cheers
Carsten
Brian Finlay
Year and Model: S60 2002
Post by Brian Finlay »
igel513 wrote:The fuel sender should be under the back seat. Pull up the seat, unfold the carpet and u'll see a round plate - access window- w/ 4 10 mm bolts. U don't have to pull d tank down.
I have accessed the tank by doing above. What is the next step to correct fault by examining or replacing. Do I need any special tools or is an experts job.
Thank You
Brian F
