I concluded that one of the power windows is no longer working because of a faulty switch. I never understood why the switches are mounted in the center console, below the cup holders, nevertheless...
In any case, I need to replace the switches and wiring, but have not been able to remove the center console. I do not want to apply to much pressure, as I already cracked some of the plastic trim.
Any suggestions? Thank You!
Remove center console in 96 850 Topic is solved
Where to Send Your Volvo ABS Module
kastel1960
thx for the reply... I didn't see anything about the actual lockout switch, but there were some instructions on replacing a light in the console of a 70... hopefully that will work for me
