Fuel Pump Relay Location S70 T5
bassline54
- Year and Model: S70 1999
- Year and Model: Many Volvos
- Been thanked: 76 times
I think your '99 should be the same as my daughter's '98. It is under the fuse box cover. You need to remove the 4 T-25 torx screws and remove the cover to get to it.
bassline54
Just returned from O'rielly with the T-25 driver. Any idea where to find info on replacing the relay or by passing it to test it. I have seen postings about use of a paper clip but not enough detail.
thxs
thxs
This thread should tell you pretty much everything you need to know.
https://www.matthewsvolvosite.com/forums ... php?t=9681
bassline54
Found the relay, did the paper clip jumper and the engine now runs properly. Will get new relay tomorrow.
A big thank you!
A big thank you!
Another satisfied customer!
I'm glad that you found your problem.
- Year and Model: Lots
- Been thanked: 128 times
The relay board can be resoldered and put back into service. We did this three years ago in my wife's 850 and not a peep out of it since. Pop the cover off with some fine screwdrivers and take a look.
If you don't solder, ask a friend to try. Ours was intermittently failing especially when under hood temperatures were higher; even when the engine hadn't run and the car sat in the sun.
- 4420 Views
Last post by wizechatmgr
- 3850 Views
Last post by Lowmiles
