Fuel Pump Relay Location S70 T5
bassline54
Year and Model: S70 1999
Post by bassline54 »
Where is the fuel pump relay located on an 1999 S70 T5?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I think your '99 should be the same as my daughter's '98. It is under the fuse box cover. You need to remove the 4 T-25 torx screws and remove the cover to get to it.
bassline54
Just returned from O'rielly with the T-25 driver. Any idea where to find info on replacing the relay or by passing it to test it. I have seen postings about use of a paper clip but not enough detail.
thxs
Post by Ozark Lee »
This thread should tell you pretty much everything you need to know.
https://www.matthewsvolvosite.com/forums ... php?t=9681
bassline54
Found the relay, did the paper clip jumper and the engine now runs properly. Will get new relay tomorrow.
A big thank you!
Post by Ozark Lee »
Another satisfied customer!
I'm glad that you found your problem.
DTX
Year and Model: 2000 Volvo S80
Post by DTX »
I'm sure the relay swith is under the hood, but I cannot distingush whick relay it is. Volvo parts says I need the number on it before they know which one it is. Does anyone know how I can tell which relay it is.
Year and Model: 2004 V70 2.5T
Been thanked: 476 times
Post by cn90 »
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The relay board can be resoldered and put back into service. We did this three years ago in my wife's 850 and not a peep out of it since. Pop the cover off with some fine screwdrivers and take a look.
If you don't solder, ask a friend to try. Ours was intermittently failing especially when under hood temperatures were higher; even when the engine hadn't run and the car sat in the sun.
