Cleaning out Cabin Temperature Sensors
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I cleaned out the cabin temperature sensors today (a pretty quick job) on my '97 855 GLT at 140K. All I needed was a fine tipped brush and a straw for blowing air to clean the sensor wires.
Location of grilles covering temp sensors:
Location of plastic 'grille' covering temperature sensors
Check the grille for dust too. One of mine was packed:
The grille was full of dust too.
The sensor wires were covered with dust:
Dirt covering the sensor
After gently brushing off the dust with a fine tipped brush and then blowing air through a straw to blow loose dust away:
Sensor after cleaning with fine tipped brush and blowing air.
Pretty fun job! :)
MNCO1
Year and Model: 850 T-5 1997
Post by MNCO1 »
Good to know. Thanks for the guide.
geokilla
Year and Model: S70, 2000
Post by geokilla »
There's more than one sensor? I thought there was only one by the wiper stalk.
2000 Volvo S70 SE; First Owner; 321km; Retired
2012 Volvo S60 T5 Level II; Gone
marginal
Year and Model: V70 D5 2003
Post by marginal »
There's two of them, one above every front door.
marginal
Post by marginal »
I just blew compressed air in mine, I am not sure it has cleaned them.
marginal
Post by marginal »
How do you take off the plastic?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
geokilla wrote:There's more than one sensor? I thought there was only one by the wiper stalk.
850's have 2 sensors; 98 and later models only one.
'98 S70 T5
2016 Chevy Cruze Premier
jreed
Post by jreed »
On my 855, the plastic grilles pull straight out with just a small amount of force. No need to pry or pull to the sides. They're held in place with a little lip of plastic and you just grasp the sides and pull out.
I tried blowing the dust away first to avoid risk to the wires from touching with a brush, but I couldn't get any of the dust to come off. So, I used a fine tipped brush (an old art brush or touch up brush) and gently brushed away the dust. Then I blew air and removed what the brush had loosened up.
Red-Arrow
Year and Model: 850 T5 1995
Post by Red-Arrow »
I did this to mines and found a broken thermistor wire, took around 30 minutes to get it out and another 30 to resolder it.
Good write up :-)
Life would be enjoyable if it wasn't so painful to live.
jreed
Post by jreed »
Interesting! What did you have to remove in order to get the sensor out?
