V70 dashboard help Topic is solved
saltydog
V70 dashboard help
can anyone tell me how I can get the climate control head unit out of my 2001 dash? I have to replace one of those $10.00 micro bulbs - please don't tell me that I have to pull the radio.
dpauto.com
- Year and Model:
Yes, radio has to be removed.
Regards,
Dave
Regards,
Dave
ASE - VOLVO Master Technician
dpauto.com
- Year and Model:
Oh, my bad .... I had that reversed. If you're only need to remove the climate, you DO NOT need to remove the radio. Sorry for the mixed up.
Basically all you have to do is remove the little trim piece below the climate control ... undo 2 screw ... then carefully remove the climate control panel.
Regards,
Dave
Regards,
Dave
saltydog
glad I checked back bfore I lit the torches....just wanted to make sure that the control unit just hooked under the radio before I started prying. Thanks a million!
dpauto.com
- Year and Model:
You have to push down and pull the climate control at the same time in order to get it out. It will fight ya for sure. Have fun !
Regards,
Dave
Regards,
Dave
