I think I got taken
Bad Used Volvo Purchase
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's an automatic override most fuel-injected cars have.
'98 S70 T5
2016 Chevy Cruze Premier
thecheat
- Year and Model: 1996 850 Turbo Wagon
I was thinking he would be in the same boat i was in with regard to performance, not changing the timing from the distrib. Wouldn't his 93 with 48,000 on the timing belt be in the same boat since the 93s have the 50k belt interval? Or am I thinking of the wrong year?jablackburn wrote:Flooring the gas pedal keeps fuel from being introduced into the engine while cranking, allowing the compression to build up to the highest possible value so you get an accurate reading without gas washing away all the oil from the rings.
Right. And now your timing is probably spot-on where it should be. But the timing can't be changed by moving the dist. cap like on some older cars.I beg to differ, I just changed my belt and water pump and we're pretty sure the belt stretched a bit. The power gains with the new belt were too significant for it not to be the case. We unscientifically compared both belts and believe the old belt was a bit longer than the new one.
jamesspringer
- Year and Model: 850 GLT, 1993
I have someone replacing the PCV valve today. I'll let everyone know how it works.
jamesspringer
Apparently, there is supposed to be a screen in there and it is missing. That is why the PCV valve is all stopped up with solids. Fortunately, the guy thinks he can clean it and get it working again. He has the kit if he needs it but doesn't think he will have to use it. He went and got a replacement screen from a junked 850 and is putting that in. The manifold gasket looks brand new and actually slipped off when he lifted the manifold. The guy who worked on this car before didn't use any gasket sealant.
Are there two flame traps in the 850? Is there one that is part of the PCV system? I know I took the one out illustrated on Bay13
and the holder was empty. This guy said the flame trap was clogged???
jblackburn
You don't need sealant on the intake gasket, as there's no coolant running through the passages in the intake manifolds of these cars.
That is the flame trap screen in the picture, and is the first part to clog; that's why most people suggest removing it. If that's clear and the rest of the system (oil sep. box and hoses) are already new, maybe the ports in the engine itself are blocked up?
'98 S70 T5
jamesspringer
Catalytic converter is completely clogged up. That explains a lot; why didn't I think of that. I got an engine code (212) yesterday that means faulty oxygen sensor. That should have tipped me off right there. That explains the high backpressure and the lack of power too. Damn, those are expensive!!
I suggested just reaming out the converter as a temporary fix until I could get a new one but a mechanic from the local Volvo dealership said that running it like that would eventually damage the engine. Whay is that?
jamesspringer
Apparently leaking badly around the valve covers now. Leaked or blew 4 quarts of oil within the last 2 days. I looked at the valve cover when I bought the car. I would have seen it if it was pouring out like that. Well I have spent the other $400 I had saved to spend on a car. Couldn't get the valve cover gasket today so I'll have to spend even more. Keep your fingers crossed that I didn't blow out another seal or two driving it today to get it fixed....
MatDesign84
- Year and Model: 1997,855 T5
I would like to know the answer to this question too James. Also I would like to say, I am not in as bad of a situation as you are but I believe I have bought (second 850 first was a 93) a bad used car. As I mentioned I had a 93 and enjoyed it for 5 years so if I can help you with anything let me know or I will let you know.jamesspringer wrote:I suggested just reaming out the converter as a temporary fix until I could get a new one but a mechanic from the local Volvo dealership said that running it like that would eventually damage the engine. Why is that?
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
jamesspringer
Thanks. I had the PCV, catalytic converter, airbox, cam seals, and flametrap replaced. A Volvo mechanic (friend of a friend) is supposed to pick up the car sometime soon and give it a good going over. His initial thopughts were that I may need the entire top of the engine rebuilt.
He said the PCV was full of solids and gunk BECAUSE the flame trap was missing. It makes sense now that I think about it. The flame trap clogs up a lot, right?. if it isn't in place, whatever usually clogs the flame trap up gets past and in where it can clog something else up. Seems to me that leaving the flame trap in place and occasionally replacing a cheap and easy to get to part beats the heck out of spending a lot more time and money tearing the engine apart to get to whatever else gets clogged up because the flame trap is missing....
- 16395 Views
Last post by xiaofei204716
- 1426 Views
Last post by vtl
- 22 Replies
- 4464 Views
Last post by kimothyanne
- 13 Replies
- 2391 Views
Last post by misha
- 1041 Views
Last post by cn90
