ECU reset
This topic is in the MVS Volvo Repair Database » 850 seat cushion foam replacement
Guest
ECU reset
Post by Guest »
Is there a way to reset the ECU, like pulling a fuse or something? I have a 98 V70 AWD
White850Turbo
Year and Model:
Post by White850Turbo »
Pull it out of it's socket and re-install.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
If you don't want to mess with yoiur ECU, you can pull the negative and positive lines off of the battery and touch them together (make sure neither is hooked up to the battery when you do this....very very important), then leave them off the terminals for 15 minutes. Reconnect and walla...you're good to go with everything reset. You'll need your radio code to do this and will have to reset your clock.
