how do i fit a bleed valve to my 850 turbo
Dealer Repairs are Expensive (Fuel Tank Leak)
t5850 mean
can anyone tell me ..give me instructions how to fit my b.valve to my 850
turbomasterfitter
1.open bonnet
2.locate vacum pipe coming from turbo actuator
3.with extra pipe if possible cut the vacum pipe as far from actuator as you can
4.fit bleed valve with lubricant if you need to to help slide in pipe
here is best adjusting guide for you ok
1.start with the valve open all the way
2.there are x2 different types ok..type 1.is anti clockwise full lock is open=less boost...adjust clockwise for more boost/
type 2.is clockwise full open =less boost as so you adjust anti.clockwise for more boost.
3.with the valve open fully (either way whichever yours is ) turn the valve x2 full 360 degrees for more boost.
4.then adjust accordingly by half a turn till the drive gets bad ,then adjust back until its at its optimum set.i.e.until you are happy with it and the car runs 100%
5.DO BE CAREFUL NOT TO TURN UP TOO MUCH,,X2 TURNS OF 360 DEGREES SHOULD BE MORE THAN SUFFICIENT....CHECK ALL YOUR PIPE CONNECTIONS ARE ALL CLAMPED UP TITE AND SECURE ..THEN B4 YOU SLAM THAT BONNET SHUT JUST HAVE A QUICK SCAN TO CHECK YOUVE LEFT NOTHING AROUND THE BAY ...CLOSE AND ENJOY ((((WITHOUT YOUR KIDS)))) LEAVE THEM AT HOME SO IF YOU CRASH ..THEY BE OK GOOD LUCK
YOU DO THIS AT YOUR OWN RISK REMEMBER
mukollt5855
thats a good a discription as any on how to fit a valve : good on you turbomasterfitter nice to see genuine people giving honest true straight help to others
turbomasterfitter
I AM ALWAYS BROWSING THROUGH THESE VOLVO SITES AND I AM HAPPY TO GIVE ADVICE TO WHOEVER NEEDS IT (I PERSONALY DONT OWN A VOLVO) I JUST FIX FIT AND REBUILD TURBO ENGINES BOTH STOCK AND HIGH PERFORMANCE.GLAD TO HELP WHOEVER NEEDS IT !!new guy wrote:i am new and just got a t5 same here [[[[[ good instructions pal
