Ok guys I have had sucess fixing my 1994 850 using all of your advice. So tonight thought it would be like any other time, few busted knuckles, a couple of frustrating moments then bamb, all in place and fixed. Well it kind of happened that way I was changing out the heater coolant hoses because the bottom one sprung a leak. All went together fine until I started putting the short hose in the bottom hole on the firewall. Had some resistance and then I heard a crack sound, looked at it felt inside hole didn't see anything wrong. So I finished putting the hose in both inlet and outlet. Put everything back together and started filling up with antifreeze. Darn a leak!!! coming out the bottom hose. Did I break or crack the heater core in this area. The reason I'm asking is I am really hoping that there is some connectors behind the plate on the firewall. Please help me and tell me some good news or not!
Thanks,
Heater Hose Replacement Problem
Luther White
- Year and Model:
- 16 Replies
- 3769 Views
Last post by PeteB
- 23 Replies
- 5832 Views
Last post by callahanoffroad
