99 S70 - ticking noise from dash
This topic is in the MVS Volvo Repair Database » Volvo Alternator replacement
sataie
Year and Model:
Post by sataie »
hi, just bought a 99S70 and there is a very annoying, relay like ticking noice when the car is moving from benhind the dash. it doesn't slow down or speed up, but only when the car is moving. it seems to be from behind the dash on the driver's side. all lights and everything seems to be working. ticking is like whne the turn signal is on. has to be a relay clicking off & on. any ideas???
marcusantonus2
Post by marcusantonus2 »
its your flasher...the are built in the hazard module... if your signals work then its working...im havin f=g problem with mine now.. :cry:
Guest
Post by Guest »
I'm having a very similar problem, except mine is from the passenger's side.
Guest
Post by Guest »
so, the turn signal and flashers are working properly on mine. do I just change the switch relay or something else??? Volvo sure is making crap since late 90s.... guess they had to compete with the rest of the garbage in the market.
White850Turbo
Year and Model:
Post by White850Turbo »
Let me know if you want a good Volvo mechanic in the DFW area. Your problem sounds like a classic '99+ electrical demon. I'm not familiar w/ the repair procedure for it however.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
