I just realised Matthews Volvo site allows pretty good picture upload support so I can just put the images directly on here without having to host them on some other website and link them.
if a moderator can embed the images in order between the text I would be grateful.
The headlining in my 1995 T5 wagon was all kinds of saggy pants, dropping blobs of fluffy orange foam that looked like dried mince meat. I didn't even take a picture as it was so embarrassing and awful. So trust me it was fugly.
I have replaced headlining before so I figure this won't be hard, its not but patience is a must. I broke a few clips from the plastic panels, typical really. Aged clips and not knowing the correct angle to remove the panels didn't help. Be careful.
So after you unclip all the trim panels, grab handles, and courtesy light and removing the sunroof trim the whole board should be ready to be dropped down and pulled out the rear of the wagon.
Once that is done you you need to pull the old cloth off and remove all the old foam as some of it will be caked on. I used 80 grit and 120 grit to work it all off, this took me a day as I was in no rush and I was thorougher.
After spraying 2 coats of Nashua 377 primer to help seal the fiber board that is very flimsy and sanding it down may have removed some strength. I let it dry for a day.
I then applied the 3M medium spray adhesive which is perfect for foam backed cloth. Do not use the heavy duty 3M as its designed for plastic or leather. It will soak the foam and bind the cloth down. I got the 3M from PepBoys for $17 a can. I had hoped 1 would do the whole board but no such luck. I had to buy another for the sunroof board. I was not going to skimp on glue here. To apply the glue you spray it from say a foot away and allow the adhesive to tac over, in other words make sure its not wet and once you put the foam down you CANNOT pull it up. You will rip the foam off the cloth. Care is required here, make sure the fabric has a small amount of tension in it. DO NOT stand or lean on the foam whilst its drying. It will leave an impression that won't come out. You don't need a size 12 foot print on your roof right
When spraying the 3M adhesive do it in a well ventilated area and wear a proper mark with vapour filters. Its a good idea to cover the ground with paper to protect it from over spray. Also wear some old horrible clothes and shoes because once it gets glue on them its never coming off. Gloves are highly recommended as well. Make sure you have good lighting so you can see what has and has not been sprayed with glue.
The headliner was purchased from a store in down town LA from a place called Micheal Lavine. $10 a yard I bought 4 yards. You need 3 yards for the main board and another yard for the sunroof.
The sun roof board comes out with easy by pressing the two clips from above but putting it back in was a nightmare! I dropped the whole sunroof assembly as I could not figure method to reinstall it. I'm still not sure how I did it to be honest.
I know the cream handles look off but it will do for now. I'm not sure Volvo did grey ones? Well I hope this makes sense and has helped someone else. Like I said its not a hard job at all. it just takes time.
